Helical Coil Using Datum Points | Step-by-Step Guide π₯π‘
π Learn how to create a Helical Coil in Creo using Datum Points! This step-by-step tutorial covers essential Creo Parametric features like Helical Sweep and Sweep Command, helping you design precise coil structures efficiently. Ideal for both beginners and experienced users! π―
πΉ What Youβll Learn:
β
How to use Datum Points for accurate coil creation
β
Applying the Helical Sweep command effectively
β
Using the Sweep Command for bent pipe design
β
Best practices for smooth and accurate modeling
π‘ Software Used: Creo Parametric 7.0
π Datum Point Coordinates (X, Y, Z):
0 0 0
-76.2 0 0
-76.2 -63.5 0
-114.3 -63.5 0
-114.3 -19.05 0
-114.3 -19.05 63.5
-114.3 31.75 63.5
-114.3 31.75 25.4
-25.4 31.75 25.4
-25.4 95.25 25.4
-88.9 95.25 25.4
-88.9 95.25 63.5
-88.9 44.45 63.5
-50.8 44.45 63.5
π If you find this helpful, donβt forget to LIKE π, SHARE π, and SUBSCRIBE π₯ for more Creo tutorials!
π₯ More Creo Tutorials: https://youtu.be/khyT2UzCpQA?si=42ioWS2Ts8TdqmV8
https://youtu.be/n4vkVEcvpUA?si=ip2pUnsJwil4V7sT
https://youtu.be/OOSoMoOq4L8?si=3mwKivQZcBL8EZVe
π Follow for More CAD Tips & Tricks!
Social media Links
Facebook page. https://m.facebook.com/cadgalaxyy/?ref=bookmarks
Instagram follow https://www.instagram.com/cadgalaxyy/
Grabcad follow chetan GOLE
π Hashtags:
#CreoTutorial #HelicalCoil #3DModeling #EngineeringDesign #CreoParametric #CADDesign #HelicalSweep #ProductDesign #MechanicalEngineering #LearnCreo
