How to create a Hex Bolt in SOLIDWorks?
Description:
SolidWorks is used to design this Bolt with the use of the simplest tools and features. All the steps are explained in detail.
The Bolt size is; M6 X 1.0
Where the diameter is 6 mm and the thread pitch is 1.0 mm. In standard, a 10 mm Wrench is used to wither tighten or loosen a M6 Bolt.
You can view the following video tutorial to learn how this Bolt CAD file is created:
https://youtu.be/Ts0yqsDonEY
This video contains only the design procedure of the Bolt, and the following videos will contain, how a stress simulation is done to this bolt, how it is rendered, and we will try to make you exposed to how a bolt is manufactured.
