HOW TO DRAW A PERFECT STAR?
Hello everyone! On this tutorial, i tried to show you "How to Draw a Perfect Star" by using "Generative Shape Design" in CATIA V5. Wish to helpful for you.
Likes are appreciated. Thanks in advance.
Go to respectively; Start> Shape> Generative Shape Design.
Click “Point” and set coordinates as X= 0, Y= 50, Z= 0. Press “OK”.
Click “Point” one more time and set coordinates X=0, Y=-25, Z=0. Press “OK”.
Select “Line Definition” for selected point and select “Create Point” on coordinates (0, 0, 0). Select line type as “Point- Direction” and pick direction as Z component. Set start distance as 12 mm.
Select (0, 50, 0) coordinated point and go to “Circular Pattern Definition”, set parameters “Complete Crown”; instances will be “5” and “Z Axis” will be the reference element.
Select (0, -25, 0) coordinated point and go to “Circular Pattern Definiton”, set parameters as “Instances and angular spacing”, instances: 5, angular spacing: 72 deg and reference element will be “Z Axis”, press “OK”.
Go to “Line Definition” and select parameters respectively as shown below.
Go to “Fill Surface Definition” and select three created lines, press “OK”.
Now, select “Symmetry Definition” as follows and press “OK”.
Select “Join” and pick two pieces to make them one part.
Step 11:
Go to “Circular Pattern Definition”, select the part that recently joined eachother and set reference element on Z Axis.
Step 12:
On join definition part select all the first created part and the rest which has created by using circular pattern definition to join eachother.
Step 13:
Select “Symmetry Definition” to create the pther half of the star. After that click to “Join” to stick two half stars.
Step 14:
The “Perfect Star” is completed. Well done!
Step 15: EXTRA
If you want to convert the created surface to a solid shape;
Go to Start> Mechanical Design> Part design and select "Surface- Based Features(Extended)" , click "Close Surface" icon and select the object and press"OK".
To give thickness to the star; select all object "Thick Surface" icon and enter the value to "First Offset" , press "OK".
