How to Draw Lamp Cover Without Create Hole
No need create hole first to draw this lamp cover. But just rotate the reinforcement.
  1. Step 1: Create surface revolved
    1. After create sketch on the front plane, then use surface revolve at 5 degrees in mid plane direction
  2. Step 2: Copy surface with mirror command
    2. Create Axis, then mirror the surface in right plane.
  3. Step 3: Flex the surface
    3. Use flex command for the two surface. For parameter, look at the description.
  4. Step 4: Mirror surface
    4. Mirror this surface.
  5. Step 5: Thicken the surface
    5. Then use thicken command for the two surfaces at 0.5mm inside.
  6. Step 6: Circular pattern command
    6. Finish step, use circular pattern for 2 thicken bodies in 40 instances.
  7. Step 7: Combine bodies
    7. Then combine for all bodies.
