How to Export Drawing file to DXF - SOLIDWORKS Task Scheduler | UBAID Tutorial
SOLIDWORKS Task Scheduler - Export Drawing file to DXF
https://www.youtube.com/watch?v=_vW3ANz3YDo
The SOLIDWORKS Task Scheduler lets you set up tasks to perform at a future time.
If you need to perform a resource-intensive task such as rebuilding a large assembly, you can use SOLIDWORKS Task Scheduler to perform the job at off-peak hours.
You can schedule a task to be performed only once or on a daily, weekly, or monthly basis.
SOLIDWORKS Task Scheduler runs separately from the SOLIDWORKS application.
You can use SOLIDWORKS Task Scheduler with any SOLIDWORKS license to convert documents to the latest SOLIDWORKS version and to dissect documents.
To schedule most other tasks or to schedule distributed file conversion, you must have a SOLIDWORKS Professional, SOLIDWORKS Premium, or SOLIDWORKS Office license.
To open SOLIDWORKS Task Scheduler:
From the Windows Start menu, click All Programs = SOLIDWORKS version = SOLIDWORKS Tools SOLIDWORKS Task Scheduler.
To access SOLIDWORKS Task Scheduler Help:
From the SOLIDWORKS Task Scheduler, click Help SOLIDWORKS Task Scheduler Help Topics.
Step 1: SOLIDWORKS Task Scheduler - Export Drawing file to DXF
From the Windows Start menu, click All Programs => SOLIDWORKS version
=> SOLIDWORKS Tools => SOLIDWORKS Task Scheduler.
- Select "Export"
- Under export dropdown you have to select which format you want to export
- But here we are selecting the AutoCAD (.dxf) format
- Now select the Solidworks drawing file (*drw,*.slddrw)
- Then click ok
