How to make a Powerful Wind Turbine with Acrylic Sheets and 12 Volt DC Motor|DIY Project
In this video you will learn how you can use acrylic sheets to build your own 100 Watts windmill.
I will use laser cutting machine to cut blades of the turbine. I have used a 12 volt dc motor from car radiator fan as a generator with some modifications.
how to modify DC motor to use it as generator watch this video: https://www.youtube.com/watch?v=2GU2AD4sEkI
