How to make twisted bar
It is not obvious to create twisted bar in SpaceClaim, e.g. for welded grating.
I hope this lifehack will help You to make it in different cad programs.
Как скрутить пруток в SpaceClaim, например для решетчатого настила.
Подозреваю, что этот способ можно применять и в других программах.
  1. Step 1: Cross section
    Create new cross section (e.g. 6x6 mm)
    Divide it half into 2 equal parts
    You'll get 2 surfaces
  2. Step 2: Axis
    Create axis from the center of cross section
  3. Step 3: Pull first part
    Select one of surfaces.
    Select "pull" in "edit", select revolve.
    Select revolve helix in revolve options.
    Choose pitch (e.g.100 mm) and height (not necessary, in this case 300 mm).
    Pull
  4. Step 4: Pull second part
    Repeat step 3 for other surface
  5. Step 5: Change of length
    Move or pull faces for align the ends
    Move or pull faces to get needed length of twisted bar
  6. Step 6: Enjoy
    Delete parasit faces and line
