how to model a nut in catia and show design intent
10 simple steps
1.create a sketch on xy plane
2.create a pad and check mirrored extent
3.select hole wizard and set extension type upto next and click position sketch
4.postion the sketch to centre
5.change the dia to 60mm
6.select zx plane. make sure you see all 3 faces of the nut(the trick here). create the sketch
7.go to groove option and select the sketch and z axis at their respective tabs
8.select groove from the model tree. now go to insert select mirror command
9.select xy plane as mirroring element under mirror tab. warning tab pop ups click yes
10.your model is ready
