How to move gear horizontally in the shaft and then rotate the gear by rotating the shaft in solidworks13?
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/1980202/feed.jpg?1448092447)
![](https://d2t1xqejof9utc.cloudfront.net/pictures/files/63484/small.jpg?1435494056)
I can show you example, but you must read HELP before asking so simple questions!
BTW, I work in SW2015, so the following images will help you.
This video show you what we'll have https://youtu.be/kEXS4TJeSi8
What we have?
1) GEAR
2) SHAFT -
1st mates:
Inner cylindrical face of the gear
Outer cylindrical face of the shaft -
2nd mates:
Two similar planes, e.g. RIGHT plane of GEAR & RIGHT plane of SHAFT -
3rd mates:
The distance between the 2 facesNow you can move gear horizontally in the shaft (changing the distance) and then rotate the gear by rotating the shaft
4th mates:
Gear mates make yourself.
