How to use swept boss in Solidworks
Here are the steps to create a swept boss in SolidWorks:
1. Start a new sketch on the plane where you want to create the swept boss.
2. Create a profile that you want to sweep along a path. The profile can be a closed or open sketch entity, such as a circle, rectangle, or spline.
3. Start another sketch on a plane perpendicular to the path of the swept boss.
4. Draw a path for the swept boss. The path can be a sketch entity, such as a line or spline, or a 3D sketch.
5. Click on the "Swept Boss/Base" command from the "Features" toolbar.
6. In the "Swept Boss/Base" property manager, select the sketch profile and path that you created in steps 2-4.
7. Choose the type of sweep you want to create: "Thin Feature," "Mid-Plane," or "Offset From Surface."
8. Specify any additional options for the swept boss, such as twist or draft angles.
9. Click "OK" to create the swept boss feature.
After creating the swept boss feature, you can modify it using the feature manager design tree and change its dimensions or other parameters.
Step 1: New sketch
Step 2: Proflie
Step 3: Plane
Step 4: Path
Step 5: Features toolbar
Step 6: Input parameters
Step 7: Sweep type
Step 8: Video demonstration
This video recaps all the above steps for how to use swept boss in Solidworks.
