I-BEAM Design in Siemens NX 1926 Beginner Tutorial | Design in NX
This video will introduce you to some of the easy and basic concept of NX 1926 Beginner Tutorial CAD design. This would show you an easy way to design an I-BEAM in Siemens NX 1926
Siemens NX 1926 software is an advanced high-end CAD/CAM/CAE 3d Modeling Tool. It is also a flexible and powerful integrated solution that helps you deliver better products faster and more efficiently. NX delivers the next generation of design, simulation, and manufacturing solutions that enable companies to realize the value of the digital twin.
Learning NX just like any other CAD software is super easy and user-friendly.
It is used, among other tasks, for:
• Design (parametric and direct solid/surface modelling)
• Engineering analysis (static; dynamic; electro-magnetic; thermal, using the finite element method; and fluid, using the finite volume method).
• Manufacturing finished design by using included machining modules.
Step 1: Making an I Beam in NX
