Project Curve Siemens Nx 10
Project Curve
Open the part file Project_Curve_model.prt.
Select Curve tab > Derived Curve group > Project Curve to display the Project Curve dialog.
The Select Curve or Point selection step should be highlighted in the Curves or Points to Project pane. Pick the indicated curve in the Graphics window.
Select the Select Object selection step in the Objects to Project To pane.
In the Graphics window, pick the indicated face on which to project the curve.
Set the Direction drop-down to Along Vector and then with the Specify Vector selection step highlighted, pick the Y-axis as indicated.
Activate Associative under Settings pane. -
Click OK create the projected curve feature.
