Taper Pin- Knuckle Joint Part 5
Learn, how to draft Taper Pin, a part of Knuckle Joint, by using Creo Parametric.
  1. Step 1: Sketch-1
    Select the top plane and click on 'Sketch'.
    Select 'Circle' and draw a circle of 6mm diameter.
    Click on 'OK'.
  2. Step 2: Extrude-1
    Click on 'Extrude'.
    Extrude the sketch by 60mm and set the taper value as 0.018mm.
    Click on 'OK'.
  3. Step 3: Final Part- Taper Pin
