Tutorial - 2D Simplification Static analysis in SolidWorks
    Start SolidWorks in Part mode.
    Tools >> Addins.
    Check the SolidWorks Simulation and SolidWorks Toolbox.
    Under Office products click Structural steel.
  5. Step 5:
    Select Front plane and the beam and click create.
  6. Step 6:
    Now we have the sketch for that particular beam.
  7. Step 7:
    Edit the sketch and move it to the center.
  8. Step 8:
    Under Simulation select New Study in Study Advisor.
  9. Step 9:
    In name type Bam and keep the default settings. Click OK.
  10. Step 10:
    Select front plane and input depth = 10000mm. Click OK.
  11. Step 11:
    Right click the part1 and apply edit material.
  12. Step 12:
    Select ASTM A36 Steel which is mostly used structural material.
  13. Step 13:
    Right click fixtures and select fixed geometry.
  14. Step 14:
    Select lower edge and click OK.
  15. Step 15:
    Select force under external loads.
  16. Step 16:
    Select upper edge and input force value 10000N.
  17. Step 17:
    Under run click create mesh.
  18. Step 18:
    Change mesh density to fine for better results.
  19. Step 19:
    Click run under run.
  20. Step 20:
    After solver is done we will have results.
  21. Step 21:
    Front view.
  22. Step 22:
    We can change the plots under results.
  23. Step 23:
    Right click Displacement and select probe.
  24. Step 24:
    Select on selected entities and then upper edge.
  25. Step 25:
    Click Update.
  26. Step 26:
    Click Plot.
  27. Step 27:
    Now we have the plot of displacement vs distance.
