Tutorial: how to create car rims in Solidworks?
Tutorial - how to make rim
please don't forget to click on ''it worked'' :)
Open a sketch and draw a rim profile like this
Draw an axis and use revolve command
This is the outer part of the your rim
Sectioning. use selection view button
Draw rims internal part profile
Again use the revolve command. and be sure that ''marge result need to be unticked
Open a sketch on front plane and draw the profile that will be cutted. This is the most important step to create your own design wheels
Use circular pattern command and make your selection according to how many arms you want to do your rim
Edit your sketch with using trim command and cut the body. to cut only revolve2 you must select it on marked area
Use fillet command and fillet your bodies
Step 11:
Drill the rim for screws
Step 12:
use your creativity
Step 13:
And renders :)) plese click on it worked button if you liked this tutorial:))
