'Tutorial: How to insert images in Autodesk Inventor'
Answer as a tutorial
1.
Click on the 'CREATE 2D SKETCH' -
2.
XZ plane, XY plane, if you are going to create a surface model of a car you will need to use the 3 plane with 3 reference images.... End Elevation, Elevation and the Plane. -
3.
Click on the image icon at top right hand side of your ribbon. -
4.
This is were you will navigate to your reference image on your computer and insert it in to the plane you have selected. -
5.
You can edit the size of your image with the use of dimensions and also constrain your image to the centre point with the use of constraints. -
6.
This is how you would go about if you wanted to edit your image. -
7.
You can rotate, flip and make the background image trasparent.
