Tutorial - How To Make a Simple Spring In Solid Edge
This is the tutorial
    Checklist the "References" in "PathFinder" to show main plane
    Sketch a circle on "XZ plane" with diameter=20mm and distances=30mm like the picture below
    sketch an axis that connect with X axis, dimension=200mm (the axis dimesion is no effect on the final result), dont forget to make circle origin "connect" with Z axis like the picture below
    In solid feature, click add>helix
  5. Step 5:
    Click the circle and axis sketch, then click "Accept" or push "enter"
  6. Step 6:
    Click "Helix Options" to show more option
  7. Step 7:
    fill the parameter:
    Helix method: Pitch & Turns
    #Turns: 5
    Pitch: 50mm
    Right-handed
    Taper=none
    Pitch=constant
  8. Step 8:
    Clik "OK" then push "enter"
    -Finish-
