Tutorial how to make belt
tutorial: How to make belt
here is the file
belt
firstly open a sketch to front plane and draw four circle like this. distance between the circles will give the belt thickness
draw two line and make it tangent with circles
use mirror command and trim your sketch
extrude the sketch
open a sketch on the side of body and draw 2 circles like this
use trim command than extrude
use features>>circular pattern command
you have to skip some of bodies which are don't touch the belt. if you dont do this, you will get error
make same things for other side
draw your tooth profile again
Step 11:
extrude it and use features>>linear pattern command
Step 12:
use mirror command
Step 13:
your belt is ready. very simple:))
