Tutorial how to make engine part 12
Crankcase
open a sketch under the body and draw this sketch.( you can use convert entities command for circles)
extrude the sketch 10 mm
go to front plane and draw this profile
mirror all bodies with using right plane
extrude the profile at each directions. after, use body-move-copy comman to translate body 15 mm on Z coordinate.
extrude it up to top plane
open a sketch on the right plane. use convert entities command.
extrude the last sketch in two directions. direction 1 is up to body and direction 2up to purple surface
crop the body
Step 11:
go to under of the body and draw this sketch
Step 12:
use linear pattern command (95 mm gab) then extrude the sketch up to pink surface
Step 13:
make same things for other side
Step 14:
crop this parts
Step 15:
open a sketch front side and draw a 30mm radiused circle. then use cut extrude command
Step 16:
open a sketch on the cylinders. draw circles like this
Step 17:
use cut extrude command. enter volues
Step 18:
please follow next tutorial
