Tutorial: How to make engine part 36
CYLINDER HEADS
use linear pattern command
open a sketch
use convert entities command
check the edges that you used for convert entities command
add a line
extrude it by 15 mm
open a sketch on this litte face
use convert entities command again
finish your sketch like shown and use extrude command
open a sketch .
Step 11:
draw two circles.
Step 12:
use cut extrude command like shown
Step 13:
open a sketch on the shown surface and draw two circles
Step 14:
Step 15:
open a sketch
Step 16:
use convert entities command. .
Step 17:
use extrude command
Step 18:
open a sketch .
Step 19:
draw two circles.
Step 20:
Step 21:
Step 22:
Step 23:
open a sketch
Step 24:
Step 25:
use extrude command
Step 26:
open a sketch on this face
Step 27:
use convert entities command. . .
Step 28:
finish your sketch and extrude it by 5 mm
Step 29:
open a sketch
Step 30:
Step 31:
extrude it
Step 32:
open a sketch
Step 33:
draw shown sketch
Step 34:
extrude it bu 8 mm
Step 35:
use fillet command on these edges
Step 36:
open a sketch on the cylinder head for the last time. I promise you, there won't be one more sketch on the cylinder head :)
Step 37:
draw the last circles
Step 38:
use the cut-extrude command at last time
Step 39:
I would be pleased to see your nice renderings here
next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-37
