Tutorial : how to render with showcase pro
open Showcase Pro
1-click on folder
2-click on your file -
1-Choose your supported file type (AutoCAD drawing (.dwg)
Autodesk 3D scene (.a3s)
Autodesk Alias (.wire)
Autodesk Inventor (.iam, .ipt)
Autodesk Packet (.apf)
CATIA V4 (.dlv, .dlv3, .dlv4, .exp, .mdl, .model, .session)
CATIA V5, incl. R20 (.catpart, .catproduct, .cgr)
Cosmo scene (.csb)
DXF (.dxf)
DirectModel JT (.jt)
FBX (.fbx)
Granite (.g)
IGES (.iges, .igs)
NX, incl. V7/7.5 (.prt)
Open Inventor (.iv)
Pro/Engineer,Creo (.asm, .prt)
STEP (.step, .stp)
SolidWorks (.sldasm, .sldprt)
Stereolithography (.stl, .stla, .stlb)
2-click open -
1-click on Lighting Environements & Backgroud
2-choose your Backgroud
3-click Library
4-choose your Environements from Library -
1-click on Adjust Lighting
2- edit your Light & shadow Setup -
1-click on Visual styles
2-choose your Visual styles
3-click Library
choose your Visual styles from Library -
1-click on Look
2- click on Shots
3- choose your shots -
1-click on Look
2- click on Materials -
1- select part to add material
2- right click in maerial and click assign to sélection -
1-click on Publish
2-click on Image -
Step 11:
1-choose Localy only
2- publish Image(s)... -
Step 12:
