Tutorial: How to save time with Bolts, nuts, washers in Auto desk Inventor.
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/8761/feed.jpg?1339781513)
![](https://d2t1xqejof9utc.cloudfront.net/pictures/files/22516/small.jpg?1370637582)
You will need to be in assemble for this, Go to the Design tap in your ribbon and click on Bolted Connection.
This will open up a box with, you can pick what method you want to use to create this bolted connection....
Linear?
Concentric?
On point?
By hole....
This is much like creating a hole on an IPT...
I have picked ' By Hole ' for this tutorial. -
1. Start plane
2. Click on top surface -
1. Existing hole
2. Click on hole -
1. Termination
2. Click on bottom plane -
Click on 'Add fasteners'
Pick what you need.
Working your way down by picking what type of
Bolt, nut, washers you require. -
Click on save Icon..
This will allow you to export the (*mxl) file
Type the file name (( what ever will suit your Bolted Connection ))
100mm 5mm???
Save to any where you want on your computer.... -
If you want to insert your new bolted connection back in to your assy
1. Design Tap
2. Bolted Connection
3. Open folder
4. Select (*mxl) file
5. Click on your the top surface
5. Click on hole
6. Click on bottom surface
