Tutorial - Jog feature (Sheet-metal) in SolidWorks?
Here is the Tutorial.
Start SolidWorks in part mode.
Top plane>>Sketch.
Draw a rectangle.
Under Sheet metal tab click Base flange/Tab.
Keep the default settings and click OK.
Under Sheet metal tab click Jog.
Select the top face of the base flange.
Create a line at 60º angle.
Exit the sketch. Now the Jog property manager will show.
Select the fixed area. The black dot represent the fixed area.
Step 11:
Change the Jog offset distance to 30mm and click OK.
Step 12:
Now we have the Jog feature obtained.
