Tutorial - Modeling machine screw in SolidWorks?
Here is the tutorial.
Start SolidWorks in Part mode.
Top plane>>Sketch.
Draw a circle of 10mm dia.
Extrude it by 25mm.
Front Plane>>Sketch and then draw this profile.
Trim down the half of the arc.
Revolve it.
Reference geometry>>plane.
Under the revolve sketch select the point and then top plane.
Plane1>>sketch.
Step 11:
Draw a rectangle of 2mm width.
Step 12:
Extrude cut at 4mm.
Step 13:
Chamfer.
Step 14:
Bottom edge at 2mm and 45º.
Step 15:
Bottom face>>Sketch.
Step 16:
Convert the outer edge.
Step 17:
Helix and spiral.
Step 18:
Pitch=2mm and Revolutions=10.5 at start angle=0º.
Step 19:
Right plane>>sketch.
Step 20:
Use polygon tool and make this profile.
Step 21:
Sweep cut.
Step 22:
Select the triangle as the sketch and the helix as the path.
Step 23:
We have the screw.
