Tutorial - Modeling USB Head in SolidWorks Part 1?
Here is the first part of tutorial.
Start SolidWorks in Part mode.
Top plane >> Sketch.
Draw a rectangle of 32mm x 15mm.
Extrude it by 7.11mm
Top face >> Sketch.
Draw this sketch.
Mirror it about center line passing through origin.
Extrude cut it by through all.
This face >> Sketch.
Draw a circle of 6.096mm dia at the mid of the center line.
Step 11:
Extrude it by 13.97mm at 2º draft.
Step 12:
Select this face >> Sketch.
Step 13:
Draw a circle of 3.048mm diameter.
Step 14:
Extrude it by 20.32mm.
Step 15:
Top face >> Sketch.
Step 16:
Draw a horizontal center line on this face.
Step 17:
Draw a rectangle of 14.478mm x 9.906mm at a distance of 4.064mm to right edge.
Step 18:
Extrude cut it by .508mm.
Step 19:
Inner face >> Sketch.
Step 20:
Draw a center line.
Step 21:
Draw a circle of 2.54mm diameter at origin.
Step 22:
Offset the center line by 2.54mm in bi-direction.
Step 23:
Convert these lines to construction geometry.
Step 24:
Draw a circle of 1.524mm diameter at 8.382 to the right of 2.540mm dia circle.
Step 25:
Draw a center point rectangle and make its side equal.
Step 26:
Smart dimension it 1.524mm.
Step 27:
Draw a triangle using polygon tool.
Step 28:
Extrude sketch by .508mm.
Step 29:
Here is second part. http://grabcad.com/questions/tutorial-modeling-usb-head-in-solidworks-part-2
