Tutorial - Using blocks in AutoCAD?
Here is the tutorial.
Start AutoCAD.
Draw a profile using pline. Click Make block icon.
Type the name of block BLOCK. Click Select objects.
Select the object.
Change the units to Millimetre.
Click pick points.
Select the base point.
Click OK.
Click Insert block.
Select the block and click ok.
Step 11:
Select the location of the base point.
Step 12:
Similarily insert the blocks.
