Tutorial - Using design table in SolidWorks?
Here is the Tutorial
Start SolidWorks in part mode.
Top plane>>sketch and draw a rectangle.
Extrude it.
View>>Dimension names.
Select the dimension and in left pane change the dimension name to lenght.
Repeat the same step for other dimension.
Insert>>Table>>design table.
change setting to Blank, Block Model edit, and uncheck all the option. Click OK.
Now excel worksheet will appear. As you click the dimension in model they are automatically added in worksheet.
Now add other instances like i added in datasheet.
Step 11:
Exit excel worksheet by clicking the workspace. Goto Configuration in Property manager.
Step 12:
Double click the grey coloured instances.
Step 13:
And here we have the different configuration for one part.
Step 14:
As we select the part we see that all dimensions are pink in color which means they are dependent on design table and configuration.
