Variable Pattern Logic used for Rose modeling
In this tutorial, you can learn How to manage Axis pattern and change easily dimensions for pattern members.
Every new pattern member can be set with a new increment (positive or negative), dependent if you want to add or remove the value from the original shape.
This method I have used for modeling of the rose leaves.
