[VIDEO] Learn How to Setup Laser Cutting Machine using SolidWorks in just 13 Minutes
In this informative video tutorial you will learn how to operate laser cutting machine using solidworks.
In this video I am going to convert solidworks design file into DXF file and then I will import that dxf file in RD works which is basically a laser cutting machine's software, at the end i will also show how to connect your PC with laser cutting machine and finally I will cut a wall clock design in acrylic material on laser cutting machine. I hope this will be a very helpful laser cutting tutorial for you.
