Hallo Guys, can you please share your innovative autoCAD Designs so that we can learn and help each other
Did you see the discussion I started. A member gave me a like to a youtube based learning tool!! Do you know ACAD 2D?
Dear Kev,
I have shared a 6000 tones per day cement plant in 3D autocad with a small movie. Because of its size I've split it into 19 departmental drawings. See < https://grabcad.com/library/1-cement-plant-limestone-stockpile-stacker-reclaimer > to < https://grabcad.com/library/19-central-control-room-main-gate-1 > and there is a navis works Cement plant < https://grabcad.com/library/cement-plant-layout-a-navis-works-presentation > Follow the instructions given so that the Freedom software gets installed. Then the whole 6000 tpd Cement will get installed on your computer. Now you can walk anywhere in the Cement Plant. You can contact me if you have any further difficulties.
Theanks
yes
Hi Friends,
Can you please any one suggest me, where can we find the Electrical Components (Relays,Contactors,MCBS i..e...) Library??
