Hello friends
I want a computer desk with the following specifications, if anyone can design, send a message.
Computer desk specifications:
Ability to assemble by the user
- Ability to adjust the height
- The components are independent of each other
- Ability to adjust the height of the mouse individually
- Lightness
Adequate strength
-Use two laptops simultaneously
-Stylish and user-friendly
thank you
Hello sir i am production engineer at wetec automation Indian private limited
It's makes Injuction molding machine related robotis automation for. Part pickup and insertmolding. And. In mould lableing
hello. i want to give an advice about that. we can start with a table that can be dismantled easily and even to adjust the height we can make with a jack system. but if you like a spacious sitting position, we make it with a model like a stacking block that can be removed and put back on as desired, for the upper part we can make a curved model with a little elbow pad so that the hands don't get sore when going to work in a long time. for the space it can be made wide, with cable holes to organize cables so they don't get scattered. the purpose of making a table with a curved model, so that the computer that is used can face it directly, without the need to reach it too far. Also on the table, there will be a place to put a glass, so that the glass is not easily knocked away or bumped while working.
The explanation you gave was very good
But I need a complete plan
Can you design?
Dear Friend,
I have made almost a similar desk few weeks ago which is currently on the process of manufacturing.
I enclosed two sample images of the product along with the Exploded View.
Looking forward to hearing from you.
Thanks
Best Regards
(toufiqi.aurin@yahoo.com)
Asm Imam
