Catia Assembly: Doubt in Constraints
I was doing a assembly and i encountered with this problem. i made the concentric constrain with the cylinder and hydraullic jack to align with their axes.. but when i move the jack axially it is moving a outside the cylinder. I want that jack to be stopped at the cylinder end. can any know how to do that? thank you in advance
5 Answer
Hi friend!!
could you please attachment a printscreen about your issue?
or another option, to do is, Could you attach your model I mean the assembly.
Have a good day,
Best Regards,
First : Never use Hybrid conception on catia V5.
as you fix the first part and the second one is in concetrical constraint use this
Answered with a tutorial: https://grabcad.com/tutorials/catia-assembly-doubt-in-constraints--2
Hi friend, I was checking your model and you are OK, with add fix to cylinder holder, and move the cylinder. I've attached an image, as a reference.
Currently I dont know if you are making a animation or kinematic movement.
Another question for you, is are they all the components? or they are missing some components.
whatever comments or suggestions just let me know.
Have a good day,
Answered with a tutorial: https://grabcad.com/tutorials/catia-assembly-doubt-in-constraints--1
