How do I import a GrabCad document into fusion 360?
I wish to print several items but I need to know how to transfer the program I downloaded it into fusion360.
interesting
First of all, it is essential to ensure that your files etc. are compatible and secondly, here are some guiding links for you to perform the process in utter ease.
https://youtu.be/H-N1LZufT_o
https://grabcad.com/questions/how-to-import-the-model-to-fusion-360
Believing that by GrabCAD document you mean a CAD file that you downloaded from GrabCAD, you will need to make sure that the files are compatible with Fusion before you import them.
Watch this video from our channel to learn the whole process!
https://youtu.be/fHjmjsyLGAs
I hope this helped! Leave us a subscription and a thumbs up for more great content.
To import a GrabCAD document into Fusion 360, download the file from GrabCAD in a compatible format (e.g., STEP, IGES, or STL). Open Fusion 360, go to the "Data" panel, and click "Upload." Select the downloaded file and upload it to your project. Once uploaded, you can open it in Fusion 360 and start working with it.
