Hello, is there a way to display the weight of a multibody part in a drawing when using an explode view?
I do add the weight in the custom property tab, but still it doesn't display the weight in the drawing.
The weight is displayed when not exploded.
In Assembly, you need to delete other part,The remaining parts need to be selected with the required materials,and you need to generate a BOM .Then you need to click the "file",and make Drawing from Assembly ,build the BOM, you can get the weight.
