Need a DESIGN TABLE Configuration for assembly file with a minimum of 6 to 7 part files
I have tried in a file which i attached below so kindly help me with that
To make a design Table , it is pretty easy
open the part file
click Insert, tables , Design table
then select the dimensions you want to change in the table
fill the excel sheet with the corresponding desired dimensions and rename the configurations
click ok
