Solidwork: my Custom specific configuration property did not upate when using several drawing tab/sheet
Hello SW expert.
I do face a problem with my workflow.
Working with several configuration within a part, my table field works fine for the first sheet I create but as soon as I add a second one, the field didn't upate when I change the drawing configuration.
None of the field are working, neither weight, description, part number... I even tried by deleting the template field link, but the value are ok before validating, after validation, the values goes back to the valu of the first Tab/sheet
I wondering what I'm doing wrong.
The drawing template have been setup with all the field link and it works fine with one configuration, but it won't work with other one if I do have more than one Tab/sheet.
I follow plenty of tutorial and I can't find where is my mistake. Thanks for your help.
