What is the difference between a design portfolio and a engineering portfolio?
안녕하세요 한국에서 디자인 엔지니어링을 공부하고 있는 20대 청년입니다.
포트폴리오를 제작하던 중 의문이 생겨서 질문합니다. 디자인 포트폴리오는 예시가 많아서 확실히 알 수 있지만 기계나, 설계 관련 포트폴리오는 접할 기회가 많지 않아 알 수 없습니다.
제 전공은 디자인공학과입니다.
내/외부 설계를 담당하고 있는데 제가 지원한 "기구설계" 가 제 과와 성격이 맞는지 궁금합니다
정확히 Enginnering 과 Design Engineering의 차이를 어떻게 보여줘야할까요?
Hello, I am a young man in his 20s studying design engineering in Korea.
I have a question while I was making a portfolio. There are many examples of design portfolios, so I can tell for sure, but I don't know about machines or design engineering portfolios because I don't have many opportunities to encounter them.
My major is design engineering.
I'm in charge of internal/external design, and I wonder if the "instrument design" I applied for is the same as the confectionery.
How exactly do I show the difference between Engineering and Design Engineering?
I didn't know English well, so I used a translator. Please excuse me.
Thank you and Happy New Year!
Industrial Design Engineering is more about the OUTSIDE and PRETTINESS of the model than the inside.
Manufacturing Design Engineering is about "CAN IT BE MADE? CHEAPLY?".
Your portfolio should reflect what skills you are trying to show off. Here is a great example of a Design Portfolio, from someone I've worked with: https://www.hobdendesign.com/
Let me know if you have more questions!
