Add tolerances to design table in Solidworks
Dear Chuck,
Imperial system tolerances is not my strong side and I create the same part in metric. Principle is same.
First create new column as the picture for header name use syntax: $TOLERANCE@Dimesion.....
in our case from part 1 in attachment
$TOLERANCE@D1@Sketch1
Create new column in your design table, for tolerance dimension on top of header use syntax:
$TOLERANCE@Dimensinon.........
in our case:
$TOLERANCE@D1@Sketch1 -
In cell for tolerances use syntax from design table.
According to the required tolerance type. -
Please check design table of Part1.
Best regards,
