AutoCAD 3d Pipe | Creating 3d pipe in Autocad | Sweep along 3D Polyline | Autocad 3d Modeling
Create a 3D Pipe in AutoCAD | AutoCAD 3d Pipe | Creating 3d pipe in Autocad | Sweep along 3D Polyline | Autocad 3d Modeling | CADable | CADable tutorials
In this tutorial, you will learn how to create a 3D pipe in AutoCAD using the sweep command. This tutorial is for beginners and will teach you the basic steps involved in creating a 3D pipe.
The first step is to set the units to inches. Then, switch to the 3D Modeling workspace. Next, draw the path of the pipe using the line command. Use the fillet command to remove sharp edges. Join the line segments to create a polyline.
Next, draw the circular profile of the pipe. You can use different visual styles to see how the pipe will look in different lighting conditions. Once you are happy with the shape of the profile, use the sweep command to create the 3D pipe.
Finally, use the shell command to give the pipe thickness. You can use the orbit command to view the pipe from different angles.
Chapters of the tutorial:
0:00 Introduction
0:20 AutoCAD Basic Settings
1:05 Creating Path of the Pipe
2:11 Applying Fillet on Sharp Edges
2:52 Creating a Polyline using Join Command
3:19 Making Circular Profile of the Pipe
3:34 Applying Sweep Command
3:53 AutoCAD Visual Styles
4:15 Applying Thickness using Shell Command
5:19 Conclusion
It is a good exercise for beginners and it will be a good practice for beginners. To practice, you can use the play pause technique. This will allow you to pause the tutorial and practice the steps at your own pace. If you have any questions, please feel free to ask in the comment section. I will try to answer each and every question.
Keep practicing as practice makes a man perfect.
Follow our Channel:
https://www.youtube.com/c/CADable
#AutoCAD3dpipe #Autocad3dmodeling #Creating3dpipeinAutocad #CADable #CADabletutorials #sweepalong3dpolyline
