Autocad 3d practice drawing | Autocad Practice Exercise 9 | Autocad Isometric Drawing | CADable
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/6944004/feed.png?1618724921)
![](https://d2t1xqejof9utc.cloudfront.net/pictures/files/248722/small.png?1697053172)
Autocad 3d practice drawing | Autocad Practice Exercise 9 | Autocad Isometric Drawing | CADable | CADable tutorials
Hi friends welcome back to CADable. This is Engr. Ibrahim Omer. In this tutorial, we will draw isometric drawing using a reference drawing. This is autocad practice exercise 9. I hope you like it.
Chapters of the tutorial:
Introduction 0:00
Creating Base Using Press Pull Command 0:57
Creating a Block Using Press Pull Command 2:30
AutoCAD 3d Move Command 3:02
Creating Last Part Using Press Pull Command 3:28
Checking One Dimension 4:34
Deleting Unnecessary Lines 4:49
Conclusion 5:00
It is a good exercise for beginners and it will be a good practice for beginners. Kindly use play pause technique for practice. Feel free to ask your queries in comment section. I will try to answer each and every question. Keep practicing as practice makes a man perfect.
Follow our Channel:
https://www.youtube.com/c/CADable
#autocadisometricdrawing #autocad3dexercises #autocadpracticeexercise9 #CADable #autocadpracticeexercises #cadabletutorials
