Best CAD Tutorial | Keyshot Render of Asus Zenbook | Keyshot tutorials
Laptop Stands are simple and amazing tools that make the usage of laptop more ergonomic and comfortable. This laptop design was designed using accurate dimensions as close as possible.
NB: I only made a mistake with the thickness of the laptops ie the elevated small portion infront to prevent laptop from falling is slightly higher than it should be. This can still be used though or you can edit the dimension.
The solid part can also be 3d printed and used if your printer is big enough
If you want to know how to 3d Print it too you can leave a comment and i would point you to one of my youtube videos that teaches you how to do that exactly
Keyshot is a powerful rendering tool for 3d models. It can be used to render all sorts of CAD files from .stl, .iges, .stp, solidworks part & assembly files etc.
Its a great software for all material rendering that gives a very good & realistic appearance
You can contact me for more specific tutorial and tuition
Whatsapp: +233241289594
Email: dadziepaulaa@yahoo.com
More models can be found here: https://grabcad.com/paul.dadzie-1/models
Facebook: https://web.facebook.com/The-CAD-Dude-101404238247458
Instagram: https://www.instagram.com/thecaddude
Step 1: Rendering the design
