Designing an IMPELLER using SOLIDWORKS
Beginner-level SOLIDWORKS tutorial aimed at improving your 3D modelling skills to the next level. I tried to simplify the steps while making the workflow as efficient as possible. At the end of this tutorial, you would be able to:
1. Create Points reference
2. Create Splines and Splines on surface
3. Create Revolve surface
4. Create Projections curves along a direction and a workaround to project curves normal to surface
5. Create Loft Surfaces
6. Split a curve using point on curve
Feel free to comment or share my profile and this tutorial link to your circle of influence.
  1. Step 1: Before you start...
    1.     Your units are set to English. Go to Document Properties -> select IPS for Units.
    2.     The model orientation is using Z-up views.
    3.     Surfaces tab is visible.
  2. Step 2: Create a sketch on the YZ plane: Sketch1
    1.     Create 5 points according to these values:
    a.     X: -2.00, Y: 0.00
    b.     X: -1.98, Y: 0.10
    c.     X: -1.20, Y: 0.70
    d.     X: -0.20, Y: 1.50
    e.     X: 0.00, Y: 2.60
    2.     Create a spline connecting all points above
    3.     Make sure the spline is horizontally constrained at the last point
    4.     Create a vertical axis line through the sketch origin
  3. Step 3: Create a revolve surface: Surface-Revolve1
    1.     Select Revolved Surface from the Surfaces tab
    2.     Use the Sketch1 to create a revolve surface
    3.     Enter 360deg as the Direction 1 angle
    4.     Click OK
  4. Step 4: Create a sketch on the offset plane: Sketch2
    1.     Create 4 points according to these values:
    a.     X: -0.20, Y: 0.59
    b.     X: 0.25, Y: 1.00
    c.     X: 0.70, Y: 1.80
    d.     X: 1.25, Y: 2.165
    3.     Exit sketch
  5. Step 5: Create projected curve on Surface-Revolve1: Curve1
    1.     Select Project Curve from Curves command
    2.     Use Sketch2 as item to project
    3.     Select Surface-Revolve1 as projection face
    4.     Click OK
  6. Step 6: Create a sketch on the YZ plane: Sketch3
    1.     Create 3 points according to these values:
    a.     X: -2.00, Y: 1.30
    b.     X: -0.50, Y: 1.80
    c.     X: -0.20, Y: 2.50
    3.     Create a vertical axis line through the sketch origin
  7. Step 7: Create a revolve surface: Surface-Revolve2
    2.     Use the Sketch3 to create a revolve surface
    4.     Click OK
  8. Step 8: Create a normal line to Surface-Revolve2 from start point of Curve1: 3DSketch1
    1.     Select 3D Sketch
    2.     Select Line
    3.     Pick start point of Curve1
    4.     Make sure the line ends outwards from Surface-Revolve1, passing through Surface-Revolve2
    5.     Multi-select the line and Surface-Revolve2
    6.     Set Perpendicular as sketch relation
    7.     Exit sketch
  9. Step 9: Create a vertical line upwards from end point of Curve1: 3DSketch2
    1.     Select 3D Sketch
    2.     Select Line
    3.     Pick end point of Curve1
    4.     Make sure the line ends upwards from Surface-Revolve1, passing through Surface-Revolve2
    5.     Exit sketch
  10. Step 10: Create a loft surface: Surface-Loft1
    1.     Select Lofted Surface from the Surfaces tab
    2.     Select 3DSketch1 and 3DSketch2 as the Profiles
    3.     Select Curve1 as the Guide Curve
    4.     Click OK
  11. Step 11: Create an intersection curve: 3DSketch3
    1.     Select 3D Sketch
    2.     Select Intersection Curve from Convert Entities command
    3.     Pick Surface-Revolve2 and Surface-Loft1
    4.     Click OK
    5.     Exit sketch
  12. Step 12: Create a loft surface: Surface-Loft2
    2.     Select Curve1 and 3DSketch3 as the Profiles
    3.     Click OK
  13. Step 13: Create a circular pattern: CirPattern1
    1.     Select Circular Pattern from the Features tab
    2.     Uncheck Features and Faces box
    3.     Check Bodies box
    4.     Select Surface-Loft2 as Solid/Surface Bodies to Pattern
    5.     Select circular edge from Surface-Revolve1 as Pattern Axis
    6.     Enter 10.00deg as Angle
    7.     Enter 2 as Number of Instances
    8.     Make sure the circular pattern arrow is pointed upwards (click on Reverse Direction if not)
    9.     Click OK
  14. Step 14: Create reference point: Point1
    1.     Select Point from Reference Geometry command
    2.     Pick inner edge of CirPattern1
    3.     Enter 1.00 as distance along curve
    4.     Click OK
  15. Step 15: Create reference point: Point2
    2.     Pick outer edge of CirPattern1
    3.     Enter 1.30 as distance along curve
    4.     Click OK
  16. Step 16: Create spline on surface: 3DSketch4
    1.     Select 3D Sketch
    2.     Select Spline on Surface
    3.     Pick Point1 & Point2
  17. Step 17: Trim surface using 3D Sketch: Surface-Trim1
    1.     Select Trim Surface from the Surfaces tab
    2.     Select the lower surface area relative to 3DSketch4 as Pieces to Keep
    3.     Click OK
  18. Step 18: Create a circular pattern: CirPattern2
    3.     Check Bodies box
    6.     Enter 5.00deg as Angle
    9.     Click OK
  19. Step 19: Create reference point: Point3
    2.     Pick inner edge of CirPattern2
    3.     Enter 1.50 as distance along curve
    4.     Click OK
  20. Step 20: Create reference point: Point4
    3.     Enter 1.93 as distance along curve
    4.     Click OK
  21. Step 21: Create spline on surface: 3DSketch5
    1.     Select 3D Sketch
    3.     Pick Point3 & Point4
  22. Step 22: Trim surface using 3D Sketch: Surface-Trim2
    3.     Click OK
  23. Step 23: Create a circular pattern: CirPattern3
    3.     Check Bodies box
    4.     Select Surface-Loft2 and Surface-Trim1 as Solid/Surface Bodies to Pattern
    6.     Enter 360.00deg as Angle
    7.     Enter 18 as Number of Instances
    9.     Click OK
  24. Step 24: Create a circular pattern: CirPattern4
    3.     Check Bodies box
    4.     Select Surface-Trim2 as Solid/Surface Bodies to Pattern
    7.     Enter 36 as Number of Instances
    9.     Click OK
  25. Step 25: Clean-up
    Make all the necessary clean-up to make sure only related surfaces are visible.
