How can I merge two or more surfaces together to have one surface?
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/missing_feed.png)
![](https://d2t1xqejof9utc.cloudfront.net/pictures/files/15886/small.jpg?1352821825)
Maybe this solution is too easy, but you only need the JOIN command
more than 40 surfaces
pick the JOIN command
select all surfaces
result: JOIN (one surface"
or if you need a "dumb" surface
create datum mode -
again the JOIN command
one "dumb" surface
