How to create custom weldment profiles in SOLIDWORKS?
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/4491884/feed.gif?1543348463)
In this tutorial I am going to show you how to create your own weldment profile.
It contains a few steps so lets start :)
Step 1: Creating a sketch
The first thing you need to do is to draw a sketch which will represent your profile shape.You can draw a sketch like mine or you can draw your own, but be aware
not to fillet anything!!
You need to search for your weldment profiles folder.
Go to Options, then File Locations and in Show folders for find "Weldment profiles".
Now down below it will show you the location of the folder.
It should be in: C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\english\weldment profiles
Weldment profiles folder is the folder where we need to save our sketch to actually
create our profile.
We will save it now, but you need to select the sketch and the go to save as.
So we opened this window, write your file name.
It is usually the size of your profile (dimensions).
Under the Save as type select Lib Feat Part.
Now you need to find the weldment profiles folder which location I showed
you in the previous step.
When you find it open it.
There should be just ansi inch and iso folders in it.
The Karajko folder I made before, do not let that distract you.
For this tutorial I made Karajko standard folder :)
You must create some folder here where the ansi inch and iso folders are and give it
some name.
Now open that folder which you created and create one more folder.
The name of this folder will represent a shape of weldment profile.
I just named it Custom profile.
Now open that folder and that is the place you need to save your sketch.
That is it ,you can see now how your profile looks.
Just make some sketch, but in a new part and choose standard Type and size.
That is why we created those folders.
This is how it looks.
You can play a little bit with these and make several types.
I hope you learned how to create custom weldment profile.
If you have some problem or if you think I missed something send me a message
and let me know :)
Karajko CAD
