SolidWorks - How to wrap a sketch onto a surface
To wrap a sketch onto a surface in SolidWorks, follow these steps:
Create a sketch on a planar face.
Select the sketch you want to wrap from the FeatureManager design tree.
Click Wrap on the Features toolbar, or click Insert - Features - Wrap.
In the PropertyManager, under Wrap Type, select Emboss, Deboss, or Scribe.
Under Wrap Method, select Analytical.
Select the face you want to wrap the sketch onto.
Set a value for Thickness.
Select Reverse direction, if necessary.
Click OK.
Step 1: Wrap an arrow on a cylinder
- Create a sketch on a planar face.
- Select the sketch you want to wrap from the FeatureManager design tree.
- Click Wrap on the Features toolbar, or click Insert - Features - Wrap.
- In the PropertyManager, under Wrap Type, select Emboss, Deboss, or Scribe.
- Under Wrap Method, select Analytical.
- Select the face you want to wrap the sketch onto.
- Set a value for Thickness.
- Select Reverse direction, if necessary.
- Click OK.
Case study presented within the following video
