SOLIDWORKS Simulation tutorial | Cantilever Beam Analysis | 3 Simulation Studies | Static Simulation
In this tutorial, we'll learn basic static simulation in SOLIDWORKS 2020. First of all, we'll model the cantilever beam in SOLIDWORKS and then we'll do simulation. Don't forget to add simulation add-in before making static simulation study. The simulation contains the following steps:
1) Define your Study (Static)
2) Assigning your Materials
3) Apply Boundary Conditions (Free Body Diagram)
4) Meshing the Model
5) Run the Analysis (Solve)
6) View the Results
After completing the first simulation, I have added second simulation by adding force parallel to the plane, here fixture is same. You can find how deformations, stresses, strains have changed.
Lastly I have one added last simulation, by changing both fixture and force, and here you will find maximum displacement on the corners (red colors) and minimum displacement on the fixed side (blue). Color contours are given where you can see the values along with different colors.
It is a good exercise for beginners and it will be a good practice for beginner
