Spring Bar
Study Lamp Spring Bar
Step 1: Draw a circle with diameter 8 mm and extrude around 3 mm
Step 2: Draw a circle with diameter 4 mm and extrude around 2 mm, than Draw a circle with diameter 8 mm and extrude around 8mm
Step 3: Draw a circle with diameter 4 mm and extrude around 20 mm
Step 4: Draw a circle with diameter 8 mm and extrude around 8 mm
Step 5: Draw a circle with diameter 4 mm and extrude around 2 mm
Step 6: Draw a circle with diameter 8 mm and extrude around 3 mm
Step 7: Shaped each edge with fillet
Step 8: Change the appearance to Gloss - Black
