tutorial 17= TRUSS analysis in ANSYS
Hello
First you should change the (Jobname), follow the path
Utility Menu >> FILE >> Change name
In the opened window put the specific name -
In second step you should choose Certain elements.
Utility Menu >>preprocessor >>Element type>> Add/Edit/Delete
In old version we choose 2D Spar but for new ones you should choose (3D finit stn 180) -
Main Menu >> preprocessor >> Real Constants >> Add/Edit/Delete
In this section we choose Unit system
Main Menu >> preprocessor >> Material props >> Material Library selection -
put material details given by question.
do not click on OK until last node, utilize APPLY instead of OK
give these points information to ansys likewise previous picture
Your points are ready for next step.
In this section we want to connect node to each other. It is better to connect node in order by this I mean, for instance connect node 1 to node 2 , and node 2 to node 3
we connect all node to each other and in subsequent step we want to give displacement details.
Step 11:
As you can see in question's picture node (1) dose not have displacement in Y direction and node (5) dose not have any displacements in any directions.
