Tutorial - Creating Conic surfaces using shoulder curves in Creo Elements/Pro aka Pro Engineer Wildfire?
Here is the Tutorial.
Start Creo element or pro engineer in part mode.
Offset the top plane by 200mm.
Offset the top plane again by 200mm but in opposite direction or input -200mm.
Select DTM2 and then Sketch.
Draw a spline and exit the sketch.
Select the Top plane and then Sketch.
Select the DTM1 and then Sketch.
Draw a spline and then exit the sketch.
Insert>>advanced>>conic surface and N-sided patch.
Step 11:
Select conic surface and then shoulder curve and then click Done.
Step 12:
Select boundaries and then select the splines in DTM1 and DTM2 while holding down ctrl key.
Step 13:
Now click on Shoulder curve and then select the splne on the top plane. And click done curves.
Step 14:
Enter the conic parameter value. Let's enter a value of 0.7.
Step 15:
Click OK and surface is generated.
