Tutorial: How to Change the Output Render Size in Vray Sketchup
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/7802365/feed.jpg?1649806983)
Tutorial Sketchup Vray: How to Change the Output Render Size in Vray Sketchup
Setting the output size of the rendering image is one of the things we must consider before starting the rendering process in vray sketchup.
By default the image size or resolution set by Vray is 800 x 600 pixels with a color density of 96 dpi and a bit depth of 24. If you feel that the size is not satisfactory, you can change it this way
Read more: Jasa Interior Tegal
- First open your sketchup
- Open the Vray options editor.
3.Open the Output tab and select the size according to your preference.
